Arms won't lower
RobNY
10-22-2004 15:12:59
Well, I have tried the quick fixes and that did not seem to work, so I pulled the cover and it looks like I bent the draft control link when the bolts snapped. So I bought the new link. No problem so far. It all came apart beautifully, except...I can not get the old draft control link out. The manual says remove the nut and cotter pin, then withdraw the draft control swivel, bushing and spring from the constant draft control link. The Problem is that the link is right against the lift shaft and there is not enough side ways movement to get the swivel out.
