Polarizing voltage regulator
8ngreenhorn
10-24-2004 04:18:56
My new battery appears not to be getting charged. To ensure correct polarization of my voltage regulator is all I have to do is run a wire directly from the battery negative to the armature connection momentarily, (a couple of seconds) and look for a spark?
Bruce (VA)
10-24-2004 06:39:06
 Re: Polarizing voltage regulator in reply to 8ngreenhorn, 10-24-2004 04:18:56
Most folks just take a flat blade screw drive and touch the BATT & ARM screws on the 8N V/R together with the key off. It will spark. Doesn't take a second. If you have a 9N or 2N, use the handles of pliers to jump across the cut-out.
JohnMD
10-24-2004 04:49:16
See below same topic 10/23. Dell explains all.
