Slow Hydraulic Lift
r2bee2
10-27-2004 22:15:26
I"m considering buying an 8N. If the hydrualics are slow coming up with a 200 pound load, what would your best guess be as to what needs to be replaced or repaired other than the obvious which is replacing the hydraulic fluid? Thanks.
souNdguy
10-28-2004 05:24:44
 Re: Slow Hydraulic Lift in reply to r2bee2, 10-27-2004 22:15:26
It would cost yuo an inspection cover gasket.. but if the owner would let you, you both could pull the inspection cover ( remove running board and cap for radious rod ) in about 5 minutes, and use a small mirror to check out the sump. If quite a bit of the oil is leaking past the piston that is where your slow lift comes from.
That's less than a hundred dollar job to replace all gaskets, a new piston and oring/washer, and a new relief valve. maybee a 190$ job if you did it all and bought a new lift cylinder to boot.. though usually honing the old one and a naa piston does the job.. Figure 4 hours work +/- to rebuild the top of the hyds.. and another 4hrs +/- if you do the bottom of the hyds.
Not a bad job.. just greasy..
Soundguy
ZANE
10-28-2004 05:14:09
Click on the link below for my file on "trouble shooting the N lift"
Zane
txblu
10-28-2004 08:48:52
 Re: Slow Hydraulic Lift in reply to ZANE, 10-28-2004 05:14:09
Nice to see you up and around dude. Glad to have you back.
Mark
Steve IA
10-28-2004 04:40:32
It may be as simple as the wrong oil in the hydraulic/xmission sump. If you get the N, one of the 1st things to do is drain and refill with proper oil. See Archives. Steve 8N I69302
Fast Ed Ohio
10-27-2004 23:05:28
r2bee2 , sounds like a week pump , not hard to rebuild, most replace the old piston with a new NAA piston , O ring , leather washer after honing out the cylinder, I rebuilt mine a few years ago, macho lifto now . The archives at the top of thi spage will give you macho info if care to use it .
