Crazy ammeter reading
8ngreenhorn
10-28-2004 17:31:56
Ammeter reads about three when tractor started, then drops slowy to -20 then went back up tp +10, all within about 20 minutes. Waddya think?
souNdguy
10-28-2004 20:45:22
 Re: Crazy ammeter reading in reply to 8ngreenhorn, 10-28-2004 17:31:56
Grab your volt meter and see what is happening with system voltage during these fluctuating readings. If the voltage stays at 'charge' voltage and doesn't drop past static battery voltage.. I'd look at trying a new ampmeter. Test both at the armature and at the battery. An analog meter may be needed for an acurate reading as some of the digitals don't like the brush noise.
Soundguy
old
10-28-2004 17:51:47
Sounds like a regulator problem but if the battery doesn't die or over charge I would probably live with it.
