Order Ford 8N Parts Online
8N/MF 35 Radius arms, end play
Robert from Que
10-28-2004 20:37:24
Should i Braise the ends to fill up the wear to tighten up these ball/joint connections on these arms or pak with something???
raytasch
10-29-2004 02:57:58
 Re: 8N/MF 35 Radius arms, end play in reply to Robert from Quebec, 10-28-2004 20:37:24
A piece of innertube makes a good shim, cheap, available, lasts a long time, easy to work with, can't be seen when installed.
ray
Dell (WA)
10-28-2004 20:48:55
Robert..... ...NO GREESE. Shimms only. Made outta nylon, teflon or copper washers. They will flow and mold around the corners..... ..Dell
Fast Ed Ohio
10-29-2004 23:52:59
 Re: 8N/MF 35 Radius arms, end play in reply to Dell (WA), 10-28-2004 20:48:55
I had a bad front end shimmy on the old 8n in 4th gear on the highway, I added copper washers to the rear balljoint connection to take up the slop, worked great,also it no longer breaks off the lower right section of the front mount dist. cap .
GAJIM
10-29-2004 06:36:45
Dell: I've got some slack in my 8N raduis arms also. What type of nylon or teflon are you recommending as a shim? Nylon fabric? Or a nylon flat washer? Thanks. GA Jim
OH Boy
10-29-2004 08:04:18
 Re: 8N/MF 35 Radius arms, end play in reply to GAJIM, 10-29-2004 06:36:45
I cut the bottom corners out of a plastic motor oil bottle and stuck 'em in the socket behind the ball and it worked well to take up the slack.
Dell (WA)
10-29-2004 08:02:49
Jim..... ....whatever plastic washer you can find at the hardware store, no big deal..... ..Dell
souNdguy
10-28-2004 20:47:54
I don't see why you couldn't braze the ball ends. Are the ball ends the worn item or is it the socket.
In any case I've seen a penny added in behind the radious rod end.. snugged it up great.. and the copper ( zinc ) wears out faster than the ball and socket...
Soundguy
Tim...OK
10-29-2004 05:20:30
 Re: 8N/MF 35 Radius arms, end play in reply to souNdguy, 10-28-2004 20:47:54
Probably not the correct way to do it,but I just took the caps off and ran a few small mig beads in the cap,seemed to work fine,that was about 6 or 7 years ago..
Tim
gahorn
10-29-2004 10:43:37
 Re: 8N/MF 35 Radius arms, end play in reply to Tim...OK , 10-29-2004 05:20:30
I like the penny idea. Bonus: Should act like an anode.
octave
10-29-2004 15:38:02
 Re: 8N/MF 35 Radius arms, end play in reply to gahorn, 10-29-2004 10:43:37
Use the leather fron a old shoe tongue
eorks good
