Randy..... ...'srite.....sparkies is sparkies even if they're made by Lucas, Prince of Darkness. Actually I don't know iff'n Fergies sparkies are made by Lucas, but I've worked on many British sportscars and their electrics were ALL by Lucas and carbs were all SU's. I may haffta gitta Fergie manual to go with my Fergie to N-Ford cross-referencing parts catalog. Heres the deal, the basic ignition coil just barely generates hot-enuff sparkies. Then when you use eather modern carbon-core anti-radiostatic suppressing sparkplug wire ...or... sparkplugs with a built-in radiostatic suppressing resistor, (8000 ohms is typical resistance) you will have used up allotta of your sparkie power and will start to miss because the electrons arn't strong enuff to jump the gap everytime. You can semi-overcome this weak sparkie problem by narrowing the sparkplug gap to make it eazier to jump the gap; and narrowing the ignition points gap to make certain you are generating the hottest sparkie you can. Howsomevers: bottom line on your old tractor, use good soft flexable copper-core sparkie wire and NON-resistor sparkplugs for besttest sparkie performance. Also use HOTTER heatrange sparkies. Modern no-lead gasoline fouls sparkies with invisable contaminates that leak the lazy sparkies away before they have a chance to jump the gap and ignite the mixture. Also use HOTTER heatrange sparkie iff'n yer tractor is a worn oilburner, keeps from fouling the sparkies so fast. As for your making the engine run better with an extra gap jumping from the sparkie wire to sparkie. This is a trick that works on aforementioned FOULED sparkplugs. (Infact you used to be able to by Champion's with a built-in air-gap inside the white insulation specifically for that purpose, jumping an oil burning engine fouled sparkplug, when you really need to rebuilt the engine to stop the oilburning) But I ain't gonnna go driving around holding sparkie wires so the engine will run smooth. Since I don't have a Champ catalog handy, I'm gonna assume that your Champs D-21's are HOTTER than the D-16's. (which is what you want) BTW RD-16 is the resistor version of the D-16..... ...Dell, the self-appointed sparkie-meister
