Order Ford 8N Parts Online
8N Hydraulic problem
Andy Gordon
10-30-2004 07:10:35
I have been experiencing an off and on problem with the hydraulic lift on my '52 8N. From time to time it gets stuck in one position - will not go up or down. The first time this happened, I drained the fluid, removed the ram assembly, but couldn't find anything obviously wrong. When I put everything back together, it worked well for a while then quit again after a month or so. This time, I monkeyed with the draft control lever a bit and it once again began working. It is working now, but I don't have a warm fuzzy feeling about it.
Any Ideas??
Thanks in Advance
ZANE
10-30-2004 13:30:34
 Re: 8N Hydraulic problem in reply to Andy Gordon, 10-30-2004 07:10:35
Click on the link below for my trouble shooting guide for the 8N hydraulic lift.
Dell (WA)
10-30-2004 08:25:15
Andy..... ...ya been monkeying with the "wrong" stuff. Its a sticky control valve down under all that oil that your "Hytrol" down lever operates. You will need to drop your hydraulic pump plate to gain access to the control valve and clean-itt. Consult your I&T FO-4 manual for proceedure..... ...Dell
