12v replacement bulbs
RichUtah
11-01-2004 21:17:52
I converted my 8n from a 6 volt to 12 volt system. Where can I find replacement lights for the headlights and work light?
RichUtah
11-07-2004 17:23:25
 Re: 12v replacement bulbs in reply to RichUtah, 11-01-2004 21:17:52
Thanks to all for your advice. I was easily able to find all the 12v bulbs I needed at NAPA and CAL Ranch store.
Jim.UT
11-02-2004 10:20:00
If you have the bulb soldered into a reflector, I can't help. But if you have sealed beams in those headlights, then go to CAL Ranch and buy two 12V sealed beam lights, #4419. I'm going from memory so I may have the number a little off. Open the box and look at the bulb. It should have two lugs on back with screws to attach the wires; one to ground and one to the hot wire....doesn't matter which.
David Cedar Falls, IA
11-02-2004 08:45:34
I bought 3 at Farm Fleet for about $8-9 each.
Dell (WA)
11-02-2004 08:42:10
Rich..... ...since both the headlights and worklites were dealer/owner installed, its hard to guess what physical size your bulbs are ...but... no matter what the physical size your 6 volt bulbs are, there are 12 volt equivalents. Just take your current 6 volt bulbs into a real autoparts store and let the counterperson help you buy the correct 12 volt bulb equivalent. Simple, eh?..... ...Dell
souNdguy
11-02-2004 05:34:49
Ditto... even online as well.
Soundguy
gahorn
11-01-2004 21:35:40
Tractor Supply Co. , NAPA.
