I know n's are different but generally speaking. The resistor came about in the early 6 to 12v conversion days when coils were wound with enough resistance (small wire) to provide ~4-5 amperes of point contact current with 6 volts across them. With the advent of 12 volts, somebody somewhere decided that they would use the same coil design, just add an external resistor to drop the extra 6 volts. Well 6 volts and 4 amperes = a 1.5 ohm coil primary and a 1.5 ohm resistor. This is not all bad as the 6 volt coil was already designed into things, people had them, the thermal profile was known so reliability of a new design was not a problem and all the good stuff. Then all they had to do is find a remote place to locate the resistor. Some coils are marked 12v. If you measure them with an ohm meter, you should measure 3 ohms in keeping with the 4-5 ampere point current. (Just this past weekend was brousing thru my MF35 Shop manual and the numbers I am speaking where there.) A coil can be tested with a sawtooth waveform (preferably; slow rise and abrupt fall) but it takes a generator and an oscilloscope to view the results. Operational on an engine is best. The problem with mounting the resistor inside the coil, or reducing the primary wire area to get twice the resistance is reliability. Instead of 6 watts dissipated in the coil (plus other losse) you now have 12 watts. Coil gets hotter. Heat kills sparkeys so reliability suffers. Only difference between point and elect ign would be voltage. Most elect ign's use higher voltage (like 40kv) whereas most older point units put out more like 18k..... as I recall. HTH Mark
