Order Ford 8N Parts Online
8n carb
northcountry
11-05-2004 15:32:49
I am getting gas to the carb but not into the bowl.I pulled the union and gas flows to it and out of the screen trap, but not into the bowl. When the bard is apart, I can blow air through, but once I put the float in and together, no air flow
What am I missing
Thanks
Dell (WA)
11-05-2004 17:33:06
 Re: 8n carb in reply to northcountry, 11-05-2004 15:32:49
El Norte..... ...most likely your float is hanging up and forcing the fuel float valve closed. When you have your carb apart the float goes with the lower bowl and doesn't close your fuel inlet valve and therefore you can blow air thru the carb gas inlet union. It oughtta be intuitively obvious iff'n you examine your float hingepin closely..... ....respectfully, Dell
