Clutch alignment
Rick(Ont)
03-10-2001 14:45:23
I'm ready to reinstall the engine on 2N, but have 1 question. I don't have access to a clutch alignment tool, but the F04 says you can remove the input shaft from the bell housing and use it. To remove this shaft do you have to drain the TDH fluid? Is there a gasket that has to be replaced? Any suggestions? Thanks, Rick
tlak
03-11-2001 04:28:43
 Re: Clutch alignment in reply to Rick(Ont), 03-10-2001 14:45:23
I used the imput shaft for my 601. Four bolts and its out, a little oil lost. Shims in there, no gasket, might put a little silicone sealer when you reinstall. Make sure your clutch pedal works when you put it back.
Timk
03-11-2001 16:51:30
 Re: Re: Clutch alignment in reply to tlak, 03-11-2001 04:28:43
You can use the input shaft no sweat. 4 bolts and it's out, you'll loose very little oil. Suggest that you might want to replace the oil seal on the shaft as long as it's out. Put a little sealant on before reinstalling. My $.02
Ron
03-10-2001 20:21:48
Many part houses have the alignment tools for this made out of plastic.
ONT RICK
03-10-2001 18:52:11
I just recently replaced clutch on my 52 8n made a wooden shaft on the lathe your more than welcome to have it Ilive just south of BARRIE I wouldnot try without it. Seems like just more work to pull shaft off trans. Mabey local NH DEALER could rent you one let me know ONT RICK
