Order Ford 8N Parts Online
8n .....no spark
Phil SO.IL.
11-08-2004 13:39:58
have an 8n, 6 volt front mount distributor was running but had a weak spark .now no spark and when i checked voltage at coil and rotated engine voltage stayed at 6+ as if the points were not closing.pulled distributor cap rotated engine and points opened and closed.wondering what i should check next.any help will be appreciated.
Fast Ed Ohio
11-09-2004 22:41:39
 Re: 8n .....no spark in reply to Phil SO.IL., 11-08-2004 13:39:58
Phil so il , your points are bad, replace them , Its a 5 minute job to remove the dist. on a front mount ( 2 half inch bolts) and it falls in your hand, new points must be set at 15 thow for proper gap, you do have a repair manual ? Im thinking you need one bad .
Ramrod
11-08-2004 14:15:01
If you put your volt meter across the coil (red on + and black on -) and saw 6v all the time, that would mean the points were stuck. That circuit is completed only when the points are closed, and when they open again, it forces the coil to fire. You may not be able to see the points open with a volt meter, but you may see a flicker as the points bounce. They will be closed most of the time, only opening when the coil is firing. You could use your ohm meter to check the internal windings on the coil, put one lead on the + and one lead on the -, it should read almost like you put the two leads together and shorted them out, as the coil is just like a long piece of wire. This is kinda advanced testing, and requires a bit of comfort factor with a VOM (Volt Ohm Meter), so if this is too geeky, we can make it simpler.
Ramrod
Phil SO.IL.
11-08-2004 15:09:37
 Re: 8n .....no spark in reply to Ramrod, 11-08-2004 14:15:01
if the + and - you are refering to is the stud and the pigtail it is reading .6 on my multimeter
KenM
11-09-2004 14:04:13
 Re: 8n .....no spark in reply to Phil SO.IL., 11-08-2004 15:09:37
Check your condenser.
Ramrod
11-09-2004 13:51:55
Let's use the Ohm Meter setting. Disconnect the wires from the two small posts on the coil. Set up the meter so that when you touch the leads together the needle swings all the way over indicating a short. Now, put one lead on the + and one lead on the -. If the needle swings way over, but not quite as far, the coil is probably good. Now put it all back together and set the meter to read volts. Put the red wire to ground on the tractor, and touch the black wire to the negative post on the battery. The meter should read 6 volts if you have a positive ground system as I think these older N's do. Now turn on the ignition and move the black lead to the - post on the coil. It should read 6 volts again, indicating a good ignition circuit. If all this is good, I would suspect the points. They will switch the ground on and off to the other side of the coil when they operate, causing a big spark to jump out of the coil to the distributor cap.
Let me know how this works out.
Phil SO IL
11-09-2004 17:15:32
 Re: 8n .....no spark in reply to Ramrod, 11-09-2004 13:51:55
ram i have a 6 volt front mount there is only one post i appreaciate the help but i think we are on different pages. i was wondering about the condenser and its part in the whole picture
Ramrod
11-10-2004 05:03:05
 Re: 8n .....no spark in reply to Phil SO IL, 11-09-2004 17:15:32
Sorry if I misled you, I'm surprised that nobody else has jumped in to help. The condenser acts to keep the points from burning up, reduces sparking as they open and close. It would probably run fine without the condenser for a while anyhow.
souNdguy
11-10-2004 05:52:36
 Re: 8n .....no spark in reply to Ramrod, 11-10-2004 05:03:05
That condensor is a good switch debouncer... I've seen points burn in minutes without a cap.
The easiest way for him to check his front mount points is to remove the coil, and then use his ohm meter on the points screw head where the pig tail touches, and measure to ground.. rotate engine by hand.. that will show the points open and close.. My guess is he has bad or coroded/dirty points..
Soundguy
