Order Ford 8N Parts Online
1950-8n
Big-B
11-09-2004 19:30:09
Hi ghy,s i have a 8n that has not ben running about 5.years how long do you ghy,s thank i should let mmo set in cylender,s
dbwillia
11-10-2004 08:03:45
 Re: 1950-8n in reply to Big-B, 11-09-2004 19:30:09
A contributor, to a car magazine, says a cup of dishwashing soap in each cylinder, will loosen up pistons in two days or less. He had used all kinds of solutions, with no results. An oldtimer told him about the dishwashing soap. He was more than pleased with the results and the engine apparently did not suffer any negative effects.
Fast Ed Ohio
11-09-2004 21:48:29
After a few days ( using the penatrating oil of your choice) leave the spark plugs out and try turning the enging over by hand . PB blaster is a good rust buster , its your tractor .
old
11-09-2004 20:37:42
Not at all. put tranny fluid in them or oil MMO is abrasive. You need to remove rust and free things up not score it worse. My $0.02
uh . . . Dell (WA)
11-10-2004 00:37:43
 Re: 1950-8n in reply to old, 11-09-2004 20:37:42
old..... .....dunnno where you gitt yer information, but as far as I know, Marvel Mystery Oil (MMO) is not an abrasive, it is a SOLVENT, not a lubricant. And works well to "un-stick" stuck rings in long-time un-run piston engines. And while ATF has detergent qualities, I'm skeptical as to its abilities to un-stick piston rings. I feel MMO is one of the very few "additives" that work as advertized. (besides, it has that neat old-fashioned red lable)..... .....respectfully, Dell
cargocult
11-10-2004 06:30:38
 Re: 1950-8n in reply to uh . . . Dell (WA), 11-10-2004 00:37:43
third party image
10-4 on the work as advertised! MMO has been around longer than I have, and I've seen it do amazing things! See the Pic for neat container that Dell was talking about! Back when I was younger, it seemed like there was a better one, but maybe I'm just getting old, hehehe!
old
11-10-2004 06:00:11
I've use tranny fluid for more then 30 years and the only thing I have found better is a 50/50 mix with turpentine.
Gaspump
11-10-2004 05:39:48
Actually the inexpensive mixture of 50% ATF and 50% kerosene has been the rust buster of choice for the offshore and marine construction industry since shortly after ATF arrived on the scene. Only thing I ever found that would loosen rusted hardware on large items such as tie-rods, pipe fittings etc in the 1-1/2' thru 4-1/2" thread diameters. Works on small stuff too!
Big-B in n-calif
11-10-2004 11:03:04
 Re: 1950-8n in reply to Gaspump, 11-10-2004 05:39:48
This sound,s like good advice. I thank that i will start with a complite tune up. then change all oil,s and rebuld the carb before trying to start the tractor.I got the tractor when i bought the house and the owner told me that the tractor did run when he parked it.
Russ in SoCal
11-10-2004 20:37:13
 did run when he parked it in reply to Big-B in n-calif, 11-10-2004 11:03:04
They all say that.
