Order Ford 8N Parts Online
size of axle nut on 8n
corvette8n
11-11-2004 16:20:00
What size socket do I need to take off the rear
axle nut, it looks a little chewed up like
someone used a pipe wrench on it.
Rick H. Ga.
11-12-2004 12:36:29
 Re: size of axle nut on 8n in reply to corvette8n, 11-11-2004 16:20:00
I just talked to the most experienced parts guy at the local NH dealer and he said the big nut is 2". He said you need a 2" wrench or a 2" socket to loosen or tighten the nut. HTH.
Rick H. Ga.
Russ in SoCal
11-12-2004 12:40:53
 Yer right, but. . . . in reply to Rick H. Ga., 11-12-2004 12:36:29
. . . some have been boogered up and ground down. Kinda like the 7/8 inch drain plug on my transmission.
Russ
Bryan in WI
11-12-2004 06:00:40
If the old one is chewed up bad, I would not waste a lot of time on it trying to get something to fit, just drill it and then wham it with a chisel and it will come right off. New nuts are about $6 as I recall. I say this because I wasted a whole day trying to get my old nut off before I stopped and thought, hey!, this is only a $6 part and I just spent hours on it. Even if you don't have a local parts place, by the time you are ready to put your wheel back on the nut will probably be at your door if you order it.
edny
11-12-2004 04:12:13
I had the same problem & bought a craftman 2" x3/4 drive Socket for about $20.00. I Also broke down and bought the t-Slide handle wench for another $20.00. It worked well since I don't have a torque wench and needed to jump on the wench to get close to 450 LBS ,since I weight in at 225 lbs .
Ramrod
11-11-2004 19:44:59
Try AutoZone. They have some cheap 3/4" drive BIG SOCKETS. I bought a couple so far for my NAA project with a 1/2" to 3/4" adapter for my impact wrench, or maybe eBay if you're up to that, but AZ is my best bet.
Ramrod
Dell (WA)
11-11-2004 18:36:15
Corvette..... ....I use a 3/4" drive, 1-7/8" 12pt socket on my 8N's rear axle nut. Torqued to 450 ft/lbs. Most shadetree mechanics don't have that size and crescent wrenches can't be fitted flat and so they slip and don't have handles long enuff and pipewrenches don't slip. Rent a 3/4" drive socketset $10 cheap..... ...Dell
Steve(OR)
11-11-2004 22:18:20
 Re: size of axle nut on 8n in reply to Dell (WA), 11-11-2004 18:36:15
Well if I say 2 inches and Dell says 1 7/8 inches, believe Dell. Maybe someone took my advice and rounded off your nut's corners. Wouldn't be the first time I exaggerated a measurement!
Gaspump
11-12-2004 15:17:23
 Re: size of axle nut on 8n in reply to Steve(OR), 11-11-2004 22:18:20
Every 8N had 2" off the assembly line, good replacements like TISCO, NH are 2". That is not to say there is no wierd or aftermarket, homemade or cobbled ones out there! A few months ago a fellow posted and swore his were 1-15/16"!
Steve(OR)
11-11-2004 16:57:26
2 inches. But if its so bad you can't measure across the nut from flat to flat it may be too chewed up to use a socket anyway.
Rick H. Ga.
11-11-2004 16:56:37
I measured mine with a tape measure and it looks like 2 inches.
I checked with NAPA about 2" socket and it was $55. I think I can do better than that on the price.
I do not consider myself a cheapscap but I never seem to have a lot of money at one time, just a little at a time:-).
Rick H. Ga.
