light wire size
Paulo
11-13-2004 21:59:50
I need to replace the light wires on my ford 8n
wondering if there is a size I need to look for?
Dell (WA)
11-14-2004 00:22:33
 Re: light wire size in reply to Paulo, 11-13-2004 21:59:50
Paulo..... ....the dealer installed 6 volt light harness used 14 gauge stranded wire out to the screw terminal on the bulb. The other screw terminal was short wired to the lightbulb shell and thru the rusty joints back to the engine ground. Me? I'd use a longer ground wire back to the engine block. You loose too much lite in rusty joints or paint inhibbitted joints. And iff'n you can't gitt two wires thru the skinny hole, drill the hole bigger..... ...Dell
Remember the 6 volt MANTRA: "keep'em clean, bright, and tight" and use biggenuff wires
Paulo
11-14-2004 18:03:30
 Re: light wire size in reply to Dell (WA), 11-14-2004 00:22:33
Thanks Dell, I am looking forward to having a little light this winter when I am plowing snow.
