Order Ford 8N Parts Online
8N Sparking
8N John
11-14-2004 22:50:57
I recently bought an 8N. I started it up tonite and noticed sparking from a bolt that holds the starter. I tightened the bolt and that seemed to do the trick. But I also notice a small glow (can see easily when it's dark) when I crank where the battery cable is grounded to the block. Is that normal??
Marty 2N IL
11-15-2004 04:55:11
 Re: 8N Sparking in reply to 8N John, 11-14-2004 22:50:57
Your ground connections are dirty or cruded up with paint. Just take them loose and clean with some emery cloth or sand paper. I would pull your starter loose and clean around it to.
Dell (WA)
11-15-2004 09:20:32
 Re: 8N Sparking in reply to Marty 2N IL, 11-15-2004 04:55:11
John..... ...what Marty sez..... .and..... ...
Remember the 6-volt MANTRA: "keep'em CLEAN, bright, and tight"..... ...Dell
