Order Ford 9N Parts Online
9N547B Draft control spring length?
Paul in VA
03-11-2001 11:54:27
The automatic draft control spring on my 2N is 5 5/8" long. Is this okay so long as it is adjusted properly? What is the lenghth of a new one?
Dell (WA)
03-11-2001 12:17:52
 Re: 9N547B Draft control spring length? in reply to Paul in VA, 03-11-2001 11:54:27
Paul..... .my Ford parts manual lists 9N-547-B, Spring (Hydraulic Lift Draft Control) as being 5.570 free length. Your 5 5/8 is same as 5.625 which is 0.005 too short.
Get a new one!!! Or give it another coat of paint to make it longer (grin)..... ..Dell
Too short?
03-11-2001 20:58:54
 Re: Re: 9N547B Draft control spring length? in reply to Dell (WA), 03-11-2001 12:17:52
Maybe 0.055" too long.
Phil (AZ)
03-11-2001 13:19:52
Del, Too Short????? ?... You Measure, I will cut.
Ray
03-11-2001 12:54:17
I'm not an expert on draft control springs but in the business I'm in; 0.05" tolerance on this size a spring is not out of the question. Being a cheapskate, I'd probably try it to see if it works.
I'd sure measure a new spring before I pay for it to see if it meets spec. It might be similar length as the old one.
