Drawbars 'n such
8NaN
11-17-2004 09:11:00
Went to Tractor Supply for a draw bar, and found nicely painted heavy stuff made in China.
Bought a "made in China" crowbar once. I bent it with my not-so-powerful upper body strength, and this made me nervous to buy a made in China drawbar.
Should I be looking for drawbars 'n such that are the same vintage as my 8N?
joe da up
11-18-2004 15:43:55
 Re: Drawbars 'n such in reply to 8NaN, 11-17-2004 09:11:00
I have a china drawbar on my naa. I got it about a year ago only using it for skidding 8 to 10 inch round logs it is shaped like a U right now. I have an drawbar that was made by ford that came with my dad's first 8n in 48 that we have jurked and skided at least 50 truck and pubs that is straiter then any thing the middle hole where the clevis is isn't even warn.
Dave OH
11-17-2004 21:17:20
Don't know about TSC Draw Bars. But when you put "'n stuff" I can tell you about sway bars. The China TSC ones will bend easily. The spring steel ones available from some of the people here do NOT bend and could save your lift arms. I found out too late!
Dave OH
souNdguy
11-18-2004 06:40:58
 Re: Drawbars 'n such in reply to Dave OH, 11-17-2004 21:17:20
Yep.. the TSC stabilizer bars are noticable less beefy than an oem set that my NAA had.
Soundguy
souNdguy
11-17-2004 12:38:03
Though I agree.. not all tsc products are 'up to par'.. I've had great luck with the drawbars. the one on my 8n will hold/pull my 16' trailer with a pallet of sod on it around the pasture.
Soundguy
Willy-N
11-17-2004 12:22:42
I just welded up my New Boom and tested it with a load over 3,000 lbs. Not bad for 40 lbs of steel doing the lifting. Was looking at the different Booms sold and they wwere rated for 500-800 lbs. The one I just finished has a 3-plus Saftey Factor for the 1,000 lbs I wanted to rate it at for a safe working load. Mark H.
mack
11-17-2004 14:23:43
 Re: Drawbars 'n such in reply to Willy-N, 11-17-2004 12:22:42
I just mmade my self up a cheap boom,out uf thick walled galv 2 1/2 in fence post. all most free. very strong. paid for that mig welder many times Mac
OH Boy
11-17-2004 11:39:00
I know what you mean. I bought one of them at TSC, though, and havent had any problems with it. Used it to pull T-posts out and it didnt bend.
You could probably get one at the New Holland Dealer that would cost twice as much if that makes you feel better!
What are you planning to pull with it?
8NaN
11-18-2004 08:06:52
 pullin... in reply to OH Boy, 11-17-2004 11:39:00
currently big hardwoods that fall in the woods. Draggin em to where I can cut them up for firewood.
But I"m sure there"s much more I can come up with to pull...
2fordsmike
11-17-2004 16:08:44
 Re: Drawbars 'n such in reply to OH Boy, 11-17-2004 11:39:00
Old ones with the right numbers are desirable and collectible.I have never heard or seen any of the newer ones (likely made in China) that were bent or damaged in any way. Mike-Iowa
Stickler
11-20-2004 09:03:19
 Re: Drawbars 'n such in reply to 2fordsmike, 11-17-2004 16:08:44
Mine's home made. Just a chunk of bar stock with pins welded on the ends. I use it mainly for skidding logs too, up to about 18" maple. But I also pull a hay rack fully loaded with it, and a square baler and it ain't bent yet, so I musta done sumpin' right. The baler did elongate the hole it mounts to a tad from the jerking, but not a bunch. My stay bars are home made too. Outta round solid bar stock, with tabs on each end.
