governor bushing
Phil@TX
03-11-2001 14:33:06
Can anybody tell me what tool or method to use to remove the bushing for the ball-drive shaft from the rear of the governor housing?
JimNC
03-11-2001 19:04:12
 Re: governor bushing in reply to Phil@TX, 03-11-2001 14:33:06
I used a tap to thread the bushing an then used a small slide hammer to pull it out. Another way that is mentioned on this board alot is to fill the hole with grease, then use a punch just big enough to fit in the hole and hit it with a hammer to force it out.
John Martinez
03-14-2001 10:44:00
 Re: Re: governor bushing in reply to JimNC, 03-11-2001 19:04:12
Use a taper or plug tap to thread bushing then
use a bottoming tap to finish threading bushing
and bushing will come right up as you keep turning
the tap. Hope this helps
Phil@TX
03-12-2001 16:49:03
Thanks, I'll give that a try.
