Help!
R.M. In AL
11-18-2004 14:27:23
My 8N frontmount has been sitting for about 2 months.Running good when parked.Always cranked quick.I got on it this week and would not fire.Getting gas ok.I thought it must be points so went and got a set and installed them.with condenser.Still no fire to plugs.Since it was running good when parked I kinda ruled out coil.It shows fire to coil but when coil wire touches coil with switch on a small blue arc occures which I assume is normal.When the coil wire is installed it shows no fire at coil.IS somthing shorted out inside the dist.Hope this is enough info.What do I need to check.Thanks R.M. In AL.
Marty 2N IL
11-18-2004 16:18:29
 Re: Help! in reply to R.M. In AL, 11-18-2004 14:27:23
Your new points may be shorting inside distributor. I would start with that then new plugs, new coil.
gahorN
11-19-2004 00:06:19
 Re: Help! in reply to Marty 2N IL, 11-18-2004 16:18:29
It"s been pretty wet around here the last few days, with lot"s of rain. My 9N wouldn"t start, and after much troubleshooting, I finally figured out that it was condensation inside the dist. cap. Paper towels fixed it, and it started right up again.
