This site
pat
03-11-2001 16:49:46
This site is so good . It sure sounds like you all can answer any problem and are not scared to help your fellow N'er that is so cool. I have had a few questions and after reading the post that are written most of the questions are already answered . I have been laid up for a lil while but plan on getting back into working on my '40 9n and I did have a quick question for you guys,, I have 55 gal. of non foaming hydraulic oil that I used for my roll backs,,, constantly blowing hydro lines,, anyway can I use this in my 9n cases or do you recommend using the 90 wt .I ask cause I have it and hope to be able to use it keep up the great site
PAT
03-12-2001 22:42:41
 Re: this site in reply to pat, 03-11-2001 16:49:46
THANKS FOR THE INFO, I'M SURE I'LL HAVE MORE ?? LAter thanks again
bj/8N/mt
03-12-2001 06:17:01
if what you have is still in the original container read the label and see if it meets Ford Spec 134D--or ask where you bought it
two schools of thought on Ford 134 and 80/90 weight--read the old posts--but if it meets Ford spec it will work
Salmoneye
03-12-2001 03:15:35
There is a difference between straight Hydraulic fluid and the Hy/Trans Fluid that is used in the rear ends of our N tractors.
Do Not Use straight hydraulic fluid!
Ken
03-11-2001 18:07:22
You can use hydraulic #134 D oil from your New Holland Dealer, it's much thinner for cold weather work.
