Order Ford 8N Parts Online
8N Motor rebuild
Sam F.
11-21-2004 09:43:37
What type of lube is best when putting my 8N engine back together ?? On the main and rod bearings, and other moving surfaces ?? Oil or grease ??
H Kutzler
11-21-2004 10:12:44
 Re: 8N Motor rebuild in reply to Sam F., 11-21-2004 09:43:37
They make a special motor assenbly grease and I believe it is made by Lubriplate. Also be sure and pack your oil pump gears with it so your pump will prime right away when you start your engine.
