Battery tester - capacitance
Rogl
11-21-2004 12:55:40
Any idea on battery tester measuring capacitance across sealed battery as used in uninterrupted power supply - UPS ? Could it be used to test regular lead acid - (not sealed) batteries ?
Thanks, rogl
Bob
11-21-2004 17:52:02
 Re: Battery tester - capacitance in reply to Rogl, 11-21-2004 12:55:40
Motorola had a car or tractor battery tester on that order years ago. I believe they were on Deere's service tool list. I had one, which I lost in a shop fire in 1983, and I have not found a replacement since.
The tester connected to the battery with small wires and alligator clips, yet could give you a good/bad readout on the battery, as well as the available CCA's, without the need for heavy cables, as typical battery load testers have.
I would still like to find a replacement for it.
Dell (WA)
11-21-2004 14:23:08
Rog..... ....most autoparts places offer "free" battery testing for lead-acid batterys. You can also get little eyedropper specific gravity testers with floating balls ($3 cheap) Most un-interruptable power supplies batterys are weak sisters compaired to your tractors lead-acid battery..... ..Dell
