Torquing Brass Nuts
Ramrod
11-23-2004 09:34:37
How much torque should be applied to a 7/16" NF brass exhaust manifold nut?
Ramrod
Vern-MI
11-23-2004 12:27:02
 Re: Torquing Brass Nuts in reply to Ramrod, 11-23-2004 09:34:37
Clean threads and read the reference URL.
Ramrod
11-23-2004 11:18:18
It musta been a 'blonde day', cause I just remembered something else I did that I know y'all would wanna comment on. Torquing down the thermostat housing, and the wrench clicks and the housings cracks at the same instant. I figure the thermostat slipped outta its little depression and got in the way. On the next try, after my new expensive housing arrives, I'm figuring on a little glue to hold the thermostat in its place. Whatta y'all say?
Ramrod
Ramrod
11-23-2004 11:13:08
Thanks guys! I got the studs torqued in at 50, then backed off to 45 and started stripping the brass nuts out DUH! Got me some new brass nuts, and gonna do this thing right as soon as I get home this evening, then gotta help whats-her-name with the turkey day stuff(ing).
Ramrod
Dell (WA)
11-23-2004 09:51:54
Ramrod..... ...my Boeing Engineers handbook lists the 7/16-20 BRASS-NUTS as 27 ft/lbs and the 7/16-14 studs as 55 ft/lbs. Always check yer studs first BEFORE you put your manifold on (prevents embarrassing leaks)..... ....Dell
tim in pa
11-23-2004 09:42:11
check this out
http://www.engineersedge.com/
Hobo,NC
11-23-2004 09:38:24
24 to 27 ft. pounds
