Engine running w/empty hydro?
8ngreenhorn
11-26-2004 14:54:45
While there isn't any hydro fluid (I'm changing and it cleaning out), can I idle my engine?
tia
old
11-26-2004 15:24:14
 Re: Engine running w/empty hydro? in reply to 8ngreenhorn, 11-26-2004 14:54:45
I wouldn't after about 5 minutes you can/could burn up the pump. Unless you keep the clutch pedel down all that time if its an N tractor that way the pump will not be running
Bob
11-26-2004 15:32:32
 Re: Engine running w/empty hydro? in reply to old, 11-26-2004 15:24:14
If the PTO is NOT engaged, the hydaulic pump will not turn.
However, the upper transmission shaft WILL be turning at engine speed without lube, and since the 8N is a constant-mesh transmission, there will be a number of gears spinning at different speeds in relation to that shaft, also without lube.
If you MUST run it, keep your foot on the clutch.
