Order Ford 8N Parts Online
ford 8Nplow
ron burkhard
11-27-2004 08:33:42
I am looking for a 2 bottom 3-point hitch plow for my ford 8N. i do not care if it is a ford plow. what should i expext to pay and does anyone have one. i am located in northern Michigan.
Dave H (NY)
11-27-2004 16:19:18
 Re: ford 8Nplow in reply to ron burkhard, 11-27-2004 08:33:42
I have seen them in TSC as well as on line in northern tools for around $250.00 after you use it you will never want to be without one.
Rick H. Ga.
11-27-2004 15:58:52
Hi Ron,
I sold a nice Ferguson 2-bottom plow in good shape back in April for $250. The price range Troy mentioned seems to be correct in my area. HTH. Rick H. Ga.
tmac
11-27-2004 14:12:39
I have a 2 bottom that came with my 9n, i have yet to even hook it up here. Located near Muskegon Mi. Not sure if i want to part with it yet but I will think about it more seriously if you like... I will try to get a photo of it for you..
Tim
ron burkhard
11-28-2004 16:13:54
 Re: ford 8Nplow in reply to tmac, 11-27-2004 14:12:39
my number is 231-985-4217 if you want to sell your plow
JOE REDNECK
11-27-2004 13:43:24
where in michigan are you located there are a few two bottams located in the u.p.for really cheap but they need some work.
Troy(IL)
11-27-2004 10:33:51
Ron,
You should be able to find one, anywhere from $100 up to $300, depending on condition and type , i personally would look for one that has the inexpensive replaceable shares, down here in central IL and especially mid Missouri, they are plentifull if you know where to look.
I personally have a Dearborn 10-1 2 14" bottom that i use with my 860, and it works well, i also have a Ford 3 bottom that i got for $150, which can be easily converted to a 2 bottom.
You might find that the 3 bottom plows go cheaper at farm auctions than the 2 bottoms do, does"nt make any sense, but that is the case around here.
