Mark Daniels, Please read!
Ron/PA
11-27-2004 11:35:48
While reading your post below, I noticed a reply that told you to remove your 6 volt battery and install a 12 volt battery. If your system is still 6 volt, DON'T DO IT!!! Ya don't need to fry your system to try a 12 volt start. You can crank your 6 volt system with a 12 volt battery, by connecting the hot lead to the starter post, and the ground to any ground on the tractor. Now as soon as you make connections it will start to crank, and if it's in gear, you'll get run over.... Don't ask ok?? This will spin your tractor faster, provided the starter is working properly, and it may start that way. This would not be a good reason to convert to 12 volt, as it would only be a temporary patch for a permenent problem. Good luck, Ron
MDOC TO RON THANKS
11-27-2004 14:10:40
 Re: Mark Daniels, Please read! in reply to Ron/PA, 11-27-2004 11:35:48
RON THANK YOU I THOUGHT IT WOULD SMOKE THE ELECTRICAL SYSTEM SO IM GOING TO TRY TO THE BATTERY
THANKS AGAIN \
MARK D
