Order Ford 8N Parts Online
Why is my 8N eating starter bendixes?
Rob 8N KS
11-29-2004 07:53:36
I seem to be stripping out the geared portion of the positive drive started bendix. I am on my second on in about 2 hours of operation.
I've had some clutch stickage issues so the first one didn't bother me, but I make sure the clutch is free before starting and I just stripped out another one. Any other ideas?
I am going to have to crack the tractor anyway to get the parts out now. So things to look for at that time would be nice.
Mrewin
06-02-2005 07:17:57
 Odd parts for 8N in reply to Rob 8N KS, 11-29-2004 07:53:36
I have an 52 side mount dist. Ford 8N in need of valve cover gaskets, Exhaust manifold gasket,exhaust gasket to tail pipe if there is one, oil drain plug gasket if there is one, & bushings for the flip seat. Where can I purchase these items no one seems to have these kind of items.
Thanks For any help, Merwin
Dell (WA)
11-29-2004 13:58:28
 Re: Why is my 8N eating starter bendixes? in reply to Rob 8N KS, 11-29-2004 07:53:36
Rob..... ...the 12 volt battery really slambs the 6 volt starter bendix into the flywheel ring. Usually this is NOT a problem. I'm thinkin' yer starter motor LONG bendix shaft might be "bent". Thens theres always the real possiblility of the starter flywheel ringgear being so worn your abnormally wearing your starter bendix too. I'd check for bent shaft and carefully reach my finger inside the starter hole and touchy-feely the ring teeth..... ...Dell
Rob 8N KS
11-30-2004 14:08:59
 Re: Why is my 8N eating starter bendixes? in reply to Dell (WA), 11-29-2004 13:58:28
how do I rotate the flywheel to examine the entire ring gear?
souNdguy
11-29-2004 12:41:04
Has this tractor been converted to 12v, and still using a 6v starter? My rebuilder says the cheap bendix sometimes don't hold up well with the conversions. Where are you getting the starter drives from? Perhaps a different type or manufacturer? There are about what? 3 different type available I think.
Soundguy
Rob 8N KS
11-29-2004 13:34:48
 Re: Why is my 8N eating starter bendixes? in reply to souNdguy, 11-29-2004 12:41:04
Bendixes are all from Tractor Supply.
The 48 8N is converted to 12V and I BELIEVE it still has the original 6V starter. It certainly looks original and I have not changed it out. I bought the tractor already converted to 12v.
b. Jones
11-29-2004 09:57:05
My step father has a 12-volt 8-n. He was having trouble with his starter also. He had the timing set too fast and it was kicking back against the starter, breaking the starter drives. It is something to check anyway.
Rob 8N KS
11-29-2004 11:38:28
 Re: Why is my 8N eating starter bendixes? in reply to b. Jones, 11-29-2004 09:57:05
Would the timing wander over time? It's been fine for over two years.
BOB061
11-29-2004 14:00:21
 Re: Why is my 8N eating starter bendixes? in reply to Rob 8N KS, 11-29-2004 11:38:28
If you are still running points your timing will change as the pionts wear.
Bob
11-29-2004 14:30:30
 Re: Why is my 8N eating starter bendixes? in reply to BOB061, 11-29-2004 14:00:21
Generally speaking, the rubbing block on the points wears more than the points, making the gap smaller and the timing LATER. (Less chance of kickback.)
BOB061
11-29-2004 15:11:00
 Re: Why is my 8N eating starter bendixes? in reply to Bob, 11-29-2004 14:30:30
That is true , it would retard the timing. But firing after top dead center could cause a kick on the back side of the drive gear until running if not throttled just right. I know this because I had this problem with my 8N. The distributor was so bad I had to set the points after an hour of use. If I did not have them just perfect and the throttle just perfect it would try to start and the starter would slam and bang untill it started. I did replace the distributor and have since had no trouble with the bendix. I am still running a 6 volt system.
Rick H. Ga.
11-29-2004 09:40:35
Sounds like you need a flywheel ring gear and an inputshaft seal. HTH. Rick H. Ga.
