Order Ford 8N Parts Online
8n carb/gov speed
arkboy
12-04-2004 02:56:23
I can't get my 8n to idle down. I've adjusted (shortened)the gov spring. The idle adjustment on the carb works (slows the motor down) if I disconnect the gov from the carb. Is the rod connecting the throttle to the gov the only other adjustment? If so should the rod be shortned or lengthened to slow down the idle?
Dale (NY)
12-04-2004 07:14:02
 Re: 8n carb/gov speed in reply to arkboy, 12-04-2004 02:56:23
Make sure the linkage is tight on the governor shaft (no side play). If its sloppy you'll need to shim it. Youd be surprised how much .006" slop on the shaft allows the lever to wobble.
ZANE
12-04-2004 05:43:32
No. Don't start cutting things. The linkage is never to be modified to acheive the desired engine speed.
Take the link loose from the throttle lever to the governor and then see if it will let the engine idle right or lower. If so look at the linkage at the bottom of the throttle rod where the link from the governor connects and make sure that the clamp bolt is tight and in the right position. There is a flat on the rod coming down that is supposed to hold the throttle lever at the bottom in place but if the clamp is loose or of the lever itself is bent which is possible you may not be able to bring it back to idle.
Also carefully inspect the carburetor throttle shaft where it enters the carburetor. The little lever with the ball on it is bradded onto the throttle shaft and this connection sometimes loosens and allows the lever to move but the throttle shaft itself to move less than it is supposed to. Sometimes you can remove the carburetor and peen the end of the shaft back enough to tighten the connection and sometimes it is necessary to braze or silver solder the connection back so it is firmly attached to the throttle shaft.
Zane
