Sherman Input Shaft
Ramrod
12-04-2004 13:40:20
Got my trannt freed up and I'm ready to close it up. Which way does the Sherman's input shaft mount? Looks like it could mount in 4 different ways. There is a slot in the input shaft housing through which you can see the shaft, does it mount up, down, left, or right? I'm thinking up...
Ramrod
boda65
12-04-2004 17:11:40
 Re: Sherman Input Shaft in reply to Ramrod, 12-04-2004 13:40:20
I think the slot should be on the bottom. This would allow any oil that leaks past the seal to drain out before reaching the clutch and pressure plate. But I could be wrong.
Willy-N
12-04-2004 14:04:23
third party image
Here is a picture showing what I think you are calling a slot. This is a 3 speed sherman and is sitting the way it goes in the tractor. Mark H.
MikeT
12-04-2004 17:46:50
 Re: Sherman Input Shaft in reply to Willy-N, 12-04-2004 14:04:23
What angle are we looking at in the pic? Is that a left side view?? What are you calling the slot?
Willy-N
12-04-2004 19:02:12
 Re: Sherman Input Shaft in reply to MikeT, 12-04-2004 17:46:50
Yes a side left view if you are facing twords front of the tractor. Slot is on the bottom. Mark H.
Ramrod
12-04-2004 14:47:57
The slot is on the bottom in the picture. I wonder what the slot is for? Y'all work on that, I'm gonna go mount my input shaft.
Thanks,
Ramrod
Willy-N
12-04-2004 19:00:07
 Re: Sherman Input Shaft in reply to Ramrod, 12-04-2004 14:47:57
I think like said above for letting fluid out that leaks pass the seal befor it travels to the end and gets to the clutch disk and ruins it. Mark H.
