ENGINE NOISE
RACHEL
12-04-2004 19:25:13
i HAVE A 9N THAT i BOUGHT ABOUT SIX MONTHS AGO.i JUST NOW HAVE BEEN ABLE TO GET IT RUNNING AND THE HYDRAULICS WORKING, IDLE TO 400 RPM, ETC. iM NOT SURE BUT i THINK i HEAR A WEIRD NOISE IN THE ENGINE AT iDLE IT SEEMS TO GO AWAY AT ABOUT 1500 RPM COULD IT BE KNOCKING? KINDA SOUNDS LIKE DETONATION COULD IT BE MY NEW WATERPUMP MAKING THIS NOISE. COULD SOME DESCRIBE TO ME WHAT AN ABNORMAL NOISE SOUND LIKE
sphargy42
12-05-2004 07:19:02
 Re: ENGINE NOISE in reply to RACHEL, 12-04-2004 19:25:13
Have any of you fellers ever seen that kind of oil pressure on a 9n ? i aint. Mine runs 5 pounds hot idling and maybe 20 hot f/a/s/w/g/-(fast as she will go)
Dell (WA)
12-05-2004 08:27:05
 Re: ENGINE NOISE in reply to sphargy42, 12-05-2004 07:19:02
sphargy..... ...your N-Oil system is pressure governed 35psi by a springloaded release valve behind a BIG bolt behind the waterpump. But NO matter what you do to spring, it won't make-up for old tired pump and worn bearing clearances.
Howsomevers, new oilpressure gauge $10 (cheap), thats where I'd start..... ..Dell
Tymoc
12-04-2004 19:45:22
A little more info please. Is the noise in the front or rear area. Does it sound like its in the head area or low in the oil pan area. Is it a high pitched ticking or a low pitched knock. How is your oil pressure at 400RPM. How bout 1500RPM.
When you let the clutch out at idle in 2nd gear does the knock get louder then settle down as you gain some forward speed. Is the oil fresh. Did this knock start only after the new water pump install?? Does the knock get louder when you first speed up the engine, does it get quieter when you quickly cut the gas back??
RACHEL
12-04-2004 19:52:19
 Re: ENGINE NOISE in reply to Tymoc, 12-04-2004 19:45:22
SUPPOSEDLY THIS ENGINE HAS NEW BEARINGS PISTONS SLEEVES A GOOD REBUILD IT GETS 50 PSI COLD AT IDLE AND 30-40 PSI IDLING HOT THE OIL IS FRESH i CANT REALLY TELL WHERE ITS COMING FROM ITS A LOW PITCHED SOUND i HAVE TO BE KINDA CLOSE TO THE ENGINE TO HEAR IT i NOTICED THE NOISE AFTER i INSTALLED A NEW WATER PUMP REBUILT THE GOVERNOR AND ADJUSTED THE FAN BELT i AM TRYING TO BE CONVINCED ITS NOT A ROD KNOCKING COULD IT BE A LIFTER OR BROKEN SPRING?
Dave H (NY)
12-05-2004 04:33:29
 Re: ENGINE NOISE in reply to RACHEL, 12-04-2004 19:52:19
Rachel, It may be as simple as a wet fan belt, let the tractor idle take a bar of hand soap and hold it against the bottom portion of the belt as it is idling, if it is the belt you'll know in a few seconds, if this makes no differance then like Dell said it is an interferance issue. Post back and let us know how you make out.
Dell (WA)
12-04-2004 21:44:53
Rachel..... ..many mechanics trace noice by using a Looonng screwriver as a hearing stethoscope. You can really locate noises that way.
I'd suppect you've gott interference problems with the parts you've replaced.
Governor: short bolt ON TOP, check'em out 'cuz longbolt will break your camshaft pulleygear $$$.
Waterpumps are known to be bad rite from the gitt-goe.
Fan can be rubbing or have a cracked blade or fanbelt be bad..... ....Dell
RACHEL
12-05-2004 09:29:14
 Re: ENGINE NOISE in reply to Dell (WA), 12-04-2004 21:44:53
THANKS TO ALL TRACED NOISE TO NOISY FAN BELT THE WIRE HAD COME OUT OF ONE SIDE.ALSO HAD A NEIGHBOR COME LISTEN ENGINE SOUNDS NORMAL TO HIM HE SAID "ITS NOT A CADILLAC" DOES MY OIL PRESSURE SOUND NORMAL?
Dell (WA)
12-05-2004 12:10:07
 Re: ENGINE NOISE in reply to RACHEL, 12-05-2004 09:29:14
Rachel..... ...Tell yer neighbor, lift his Caddy hood and listen to its engine noise, worse'n tractor but it all gitts hidden and covered up by the hood and you set inside an insulated and padded driver bedroom.
lotta guys would call them oilpressure readings "braggin' pressures". They are good for new engine rebuild. Its normal for cold oil to have higher pressure reading. Glad you found your noise. Lotta'us ol'timers can't hear nuttin so we gotta cheat by using long screwdriver (grin)..... ..Dell
Russ in SoCal
12-05-2004 18:52:46
 Re: ENGINE NOISE in reply to Dell (WA), 12-05-2004 12:10:07
There ya go lyin" Dell. Them pressures are NOT normal fer an N. Near all of em are worse.
Russ
