Carb rebuild suggestion,old guitar strings.
rasputen
12-09-2004 21:33:25
Rebuilt my TSX-33 tonight. Came up with a tip or 2. Followed Zanes suggestion of lapping the 2 halves, seemed to do the trick as it runs better than ever. Thanks Zane!
I see a lot of talk about welding tip cleaners, and am sure they work great. But I use old guitar strings cut off about 6 inches from the brass ring (at the bridge end). These work great & there are 6 different sizes!
Hope yall' can save some money, everybody at least should know somebody that plays if _you_ don't, just ask for the old strings.
BTW, got rid of all the sputtering except the ocasional one at very low idle. B4 I could only get a smothe 400 RPM idle with 1/4 choke. Now I can get it really adjusted with the idle jet alone & choke does not help like b4. Running above idle is smother than I ever have had b4, I was blaming valves, but it seems just to have been the carb.
Jim.UT
12-10-2004 15:51:21
 Re: Carb rebuild suggestion,old guitar strings. in reply to rasputen, 12-09-2004 21:33:25
Good tip! My son plays. I'll let him know that I need his old strings next time he changes them.
