7naa
T. Ballard
12-10-2004 09:33:40
My tractor seems to be running great.
Idles and revs well and all hydrolics are functioning.
When I put any kind of "load" on it, ie. climbing slight inclines, it looses power and dies.
Checked the spark by pulling the plug wires from the cap, all are sparking good.
I am not a mechanic but I like to work on it myself.
Hoping someone out there may have some ideas for me.
Thanks, Tony B.
mattd
12-10-2004 18:12:54
 Re: 7naa in reply to T. Ballard, 12-10-2004 09:33:40
i had the same exact probelm a couple days ago. it turned out that the points had to narrow of a gap. so i opened the gap on the points and now it doesnt miss at all no matter how big of a load its pulling. hope this helps
T. Ballard
12-11-2004 09:43:29
 Re: 7naa in reply to mattd, 12-10-2004 18:12:54
Thanks,
I tried everything else mentioned in the replies to my question, with no luck.
However, I want to thank everyone for offering suggestions.
It just does not seem to be fuel related.
I will try to open the points.
Let you all know.
Thanks.
Polish Mike
12-10-2004 11:20:31
How long does it take once you put the load on it to start sputtering and dying ? Have you cleaned out your sediment bowl and all 3 filter screens lately ? Any water in the gas tank ?
I know the popular saying here that most fuel problems are really electrical, but on my NAA the only time it sputters is if I'm going up a hill & the fuel level is low, or there's a bunch of crud in the filters or sediment bowl. Sounds like it's starving for fuel...
T.Ballard
12-10-2004 11:59:42
 Re: 7naa in reply to Polish Mike, 12-10-2004 11:20:31
Thanks.
I had a leak in the line from the point where the bowl attaches to the tank, so I changed the entire unit. Its brand new, with new fuel.The two screens in the bowl are new. I did not know there was a third. Can you tell me where?
Thank you.
Polish Mike
12-10-2004 12:09:32
 Re: 7naa in reply to T.Ballard, 12-10-2004 11:59:42
One at the glass sediment bowl, one at the elbow going into the carb, and one on your shut off valve , inside the fuel tank...You have to take the valve off to reach it. I'm sure someone has a picture that shows all three...
( Pic ) Ken N Tx
12-11-2004 04:28:55
 ALL THREE in reply to Polish Mike, 12-10-2004 12:09:32
third party image
ron francis troncatty
05-30-2006 07:08:46
 BACK AT CHA BOB in reply to ( Pic ) Ken N Tx, 12-11-2004 04:28:55
One: your not suspecting I fried the coil then?
Two: I don't have the first of the three filters.....instead I have a conventional in line fuel filter from Pep Boys that I already blew out..... ...but I can check the other two....the elbow filters seems easy to remove and check but where is the flat screen filter located..... .do I have to tear the carb apart to get to it?
T.Ballard
12-10-2004 12:22:00
 Re: 7naa in reply to Polish Mike, 12-10-2004 12:09:32
Thanks,
I did not know about the one at the elbow.
I will check it.
It's got to be something simple. I hope..... ...
old
12-10-2004 09:49:01
It maybe running lean or you may have a clogger main jet in the carb.
T.Ballard
12-10-2004 12:04:55
 Re: 7naa in reply to old, 12-10-2004 09:49:01
Thanks, I'll check the carb.
If I am too lean, is there a good source of instruction for setting the carb?
I have a shop manual (reprint), but it does not cover the basics very well.
Thank you.
old
12-10-2004 12:29:20
 Re: 7naa in reply to T.Ballard, 12-10-2004 12:04:55
It should be the adjustment one the bottom of the carb just open it up a half turn at a time and give it a try
