bog down under load such as pulling a mower
rward
12-11-2004 13:08:54
I have a 1948 8n tractor,startsup good cold or hot ,when i pull the mower on unlevel ground it starts running rough - slows down - acting as if flooding out. I can push in clutch or disingage the pto and the tractor will run smooth . If i allow the tractor to stall out and die it is very hard to restart ( takes a long time to restart)I have installed new plugs gaped at .025 - new plug wires- the coil was new with new points-condenser-rotar cap - distributor cap - the carburator has been rebuilt. I am not sure what the point gap was set at(does the distributor need to be removed to check points ,distributor is on front) also what is the proper setting for the float and how do you set it. When the tractor sets over night without the fuel valve closed gas will drip out of the carburator air intake .
kenny b
12-11-2004 17:07:12
 Re: bog down under load such as pulling a mower in reply to rward, 12-11-2004 13:08:54
I had the same problem and was given the same advice you are getting i tried everything and finally found out by trial and error that it was the weight and cam assembly new cost69dollars but it cured my problem
rward
12-11-2004 19:53:04
 Re: bog down under load such as pulling a mower in reply to kenny b, 12-11-2004 17:07:12
Kenny b I received your reply on my situation , what is the weight and cam assembly ? Please elaborate on this subject .
MikeT
12-12-2004 08:13:37
 Re: bog down under load such as pulling a mower in reply to rward, 12-11-2004 19:53:04
He's talking about the weights inside the distributor. As the speed of the engine increases, the weights fly outward to change the engine timing. They get crudded up quite often and quit doing their job. Either get a new distributor or take the time to clean out the one you have.
Bruce (VA)
12-11-2004 13:31:36
Easy one first..... replace the shut off valve on the sedimet bowl; that is the start of your leak. Replacing the needle valve, seat & float would also be a good idea. Kits are about $30 bucks. On the engine problem.....check the point gap; they often slip. Gap is .015, and removing the distributor is easy. If the point gap is ok, pull the linkage to the carb from the governor w/ the engine running & see if the governor pulls back. If not, you might have a governor problem. I'd check the points first though, because it it a likely solution & easy to do.
