engine bogs down
RACHEL
12-11-2004 17:37:19
The engine on my 9n seems to bog down some.I was box blading my gravel drive way and noticed with a full 5foot box blade of gravel the engine rpm would seem lower than what I set my hand throttle at.but not enough to kill the engine I still had plenty of power to get the job done I noticed this problem after I rebuilt the carb and rebuilt the governor at the same time when I put it all back together I had to bend the gov to carb linkage to get the high rpm down to 2200 it wanted to be a lot higher without it bent
the tractor idles at 400 rpm and full throttle is 2200 Is it the governor adjustment if so what next I bent the rod and that d##M spring until I am exhausted any help would be appreciated
Russ in SoCal
12-11-2004 19:54:58
 Re: engine bogs down in reply to RACHEL, 12-11-2004 17:37:19
Rachel,
Sounds like your carburetor is hitting it"s stop. By setting the "full throttle" position on the governor back, it has more travel than the carburetor is willing to give.
Russ
