Order Ford 8N Parts Online
8n, 1952 side mount 12 v conversion
phil hays
12-11-2004 20:06:06
I have installed a 12 v conversion on my 1952 8n, side mount dist. from one of the site suppliers. The kit came with a resistor in order to use the old 6v coil. The kit was easy and seemed to work great, but after an hour of work the coil burned out. I measured voltage out of the resistor to the coil; instead of less than 6v, I read 13v--which would explain the coil. I am now wondering whether to replace with another 6v coil (and replace the resistor which was apparently faulty) or to use a 12v coil. If I use a 12v coil, what sort of resistor will I need?
Hobo,NC
12-12-2004 07:05:23
 Re: 8n, 1952 side mount 12 v conversion in reply to phil hays, 12-11-2004 20:06:06
IC-14-SB $14 IC-14 $30 add the SB to save money. Throw the resistor away. I think this is a standard part # enny were if not they shoud be able to cross reference it.
Bob
12-11-2004 20:11:55
The resistor will only drop the voltage to 6 Volts when there is current flowing in the primary circuit... points closed, coil primary in OK condition.
If the points are not closed (or not making contact), or the coil primary is burned out, there will be no current flow, and you will read full battery voltage at the coil.
Simply toss the old coil and resistor, and get a REAL 12 Volt coil that specifically states no ballast resistor is needed.
Dell (WA)
12-11-2004 20:20:43
 Re: 8n, 1952 side mount 12 v conversion in reply to Bob, 12-11-2004 20:11:55
Phil..... ...what Bob sez..... .and..... ..NAPA IC-14 is a real 12 volt roundcan ignition coil that used NO RESISTOR..... ....Dell
john in la
12-12-2004 06:06:24
 Re: 8n, 1952 side mount 12 v conversion in reply to Dell (WA), 12-11-2004 20:20:43
Napa also has a non Napa brand coil # IC-14SB for a little less money.
