Hammer helps
Paul in MD
12-12-2004 13:29:43
Couldn't start my 8N today. Just got the ol' click sound at the relay. Cleaned and tightened all connections and charged the battery to no avail. Got out a hammer and tapped on the starter and it started right up. I guess as long as a hammer fixes it, I won't worry too much about it (or should I?).
Paul in MD
12-13-2004 04:09:55
 Re: Hammer helps in reply to Paul in MD, 12-12-2004 13:29:43
I'm sure it's ready for a rebuild. I have no idea how old it is or when it was last rebuilt. I guess that's the smart thing. Thanks for the advice.
Hobo,NC
12-12-2004 16:17:46
It may start a 100 times and may only start 1 more time with yer hammer its your call. Starter worn out or bad connection at the starter I think the hammer is tell地 ya sum段n are ya list地.
Bob
12-12-2004 16:06:26
The problem was likely stuck brushes, or corrosion between the three sections of the starter, or between the drive-end frame and the engine bellhousing.
SteveB(wi)
12-12-2004 15:29:46
I would at a minimum carry a hammer. When I had to hit mine last summer every few times I opened it up and decided it needed a rebuild. I think it cost me about $15 in parts including bushings and a soda for the machinist at work to cut the armeture. Took about 2 hours to rebuild including undercutting the mica and getting the old bushing out of the end plate.
raytasch
12-12-2004 14:32:42
Should you worry? Depends on how urgently you need the tractor sometime. Might never happen again. If the problem was something like a brush sticking from dirt, a weak spring, or a worn brush, the problem will show up again, perhaps when you need to use the tractor the most; like there is a foot of snow that needs plowing. Maybe you would be way out in the woods or even stopped awaiting a parade to start. I'd check it out at my convenient time.
ray
