Question for Dave H (NY)
Phillipm
12-13-2004 11:38:08
Dave, saw your question to Dell on 12/8/04 and his answer. I too now have the 2 resistors in my hand, but since auto elect. is not my field it is not intuitively obvious to me as to whether or not The pigtails are to be twisted together in series or in parallel. Would've asked Dell, but I just tuned in and saw he is on a trip. If you or anyone could help with this I would appreciate it.
Thanks,
Phillip
Dave H (NY)
12-13-2004 13:12:48
 Re: Question for Dave H (NY) in reply to Phillipm, 12-13-2004 11:38:08
Phillip, I just saw your message Tim's picture is exactly correct, I put the resistor set on my 2n and it works fine. Good luck Dave
TIMW(PA)
12-13-2004 13:06:33
 resistor(pic) in reply to Phillipm, 12-13-2004 11:38:08
third party image
As often as this little trick is described i have never seen a picture of one for people to learn from so I made one up today. The wires on the end would need to be soldered..hope it helps Tim
John Norquist
12-14-2004 17:53:24
 Re: resistor(pic) in reply to TIMW(PA), 12-13-2004 13:06:33
Are you SURE the wires get twisted clockwize? I don't think it would matter on an AC circuit, but this is DC.
Ho,ho,ho!
Jay 2NSC
12-14-2004 15:45:22
Thank you Tim,it help"s alot. Us electricly challenged folk"s appreciate it very much. :^)
Jay 2NSC
Phillipm
12-14-2004 08:36:50
Thanks Tim,
That helps a lot. Phillip
Bob
12-13-2004 11:46:24
You take two 1 Ohm resistors, connect them in PARALLEL (put them side-by-side and twist the leads together, and solder them together).
The two 1 Ohm resistors in parallel give a resistance of .5 Ohm, as Dell specified.
