At wit's end
status update
Alex Dula
03-14-2001 09:15:49
Thanks for all the suggestions. I took the block and crank back to the machine shop. He spent an hour doing everthing he could think of and came to the same conclusion that the front cap/bearing is not inline with the crank. He said the next step would be to inline bore the block/bearings. Will keep ya'll updated after the work is done. By the way the front bearing is showing wear after being torqued to 20-30 ft-lbs. The crank micked out at 2.249 on all three bearing areas.
Alex
