Andy, I see your problem! The sparkplug wires are not connected to the distributor! Just kidding! I'll cover the basics and let the experts cover the hard parts. The coil is the black thing in your picture above. To remove the coil, flip the bail out of the way and disconnect the wire on top. Coil will now come out. There should be a cork gasket between the coil and the distributor/cap. The tan colored thing in your picture is your distributor cap. To remove it, flip the 2 clips and it will come out. The distributor can now be removed by removing the 2 bolts. You can see one of them in your picture. It has the red head behind the fan belt. Before removing the distributor, notice where the rotor is facing. This will help when you replace. You can set the point gap with the distributor off the tractor. Check for broken wires, especially the thin metal strap that connects to the points. When reinstalling, point the rotor where is was when you took it off. It should slip all the way in. You may have to wiggle the rotor to get it all the way in. Reinstall dist. cap and coil with gasket. Connect the wire to top of coil. Use a multimeter (volt/ohm meter) to check the voltage to the wire on top of the coil. With the switch on, it should be battery voltage with the point open. I'm not sure what the voltage should be with the points closed since you have converted to 12 volts. On my 6 volt front mount, I get about 3.5 volts with the point closed. Once you measure the voltage with points open and point closed, post back. My $.02 worth, Danny
