Cross-posting from Fergie site: adding a pump
Rod in Smiths F
12-18-2004 21:45:38
Is there a slick way to tie an after-market hydraulic pump to the crankshaft of a Ferguson TEA20 so as to have live hydraulics?
I'm thinking along the lines of replacing the crank fitting with some sort of twist-in spline which could drive the pump at engine speed, but a belt and pulley might work, as well.
My dad's old Freeman loader would look a lot better with with a good pump pushing it and possibly an extra cylinder to tip the bucket.
Thanks.
lonestarjeff
12-21-2004 00:07:32
 Re: Cross-posting from Fergie site: adding a pump in reply to Rod in Smiths Falls, ON, , 12-18-2004 21:45:38
Rod:
I"ve got some pics of my pump/loader front bracket for my 8N. I may have some snapshots out of the manual showing the pump & bracket installed.
Let me know if you need"em. Leave me your email address or I can post"em in "parts & pieces" gallery.
Jeff
12-21-2004 16:22:06
 Re: Cross-posting from Fergie site: adding a pump in reply to lonestarjeff, 12-21-2004 00:07:32
I'd definitely like to see the pictures.
rodcros@webruler.com
Thanks,
Rod
SteveB(wi)
12-19-2004 12:20:39
Do a search in the parts and pieces under "front pump" and a few things will come up. Here is one nice setup.
ZANE
12-19-2004 05:47:59
I'm not sure which engine the TEA Ferguson has but I have developed a system for live hydraulics for the TO Fergusons with the contintenal engines. It would work on other engines no doubt if the engine configuration was the same so that the pump mounting bracket would work. I use a gear pump that is belt driven and the oil supply is taken from the sump of the original drive train/hydraulic system. With my system you have live hydraulics to the three point hitch and you can also use a front end loader or other remote hydraulics by tapping into the pressure hose for a remote control valves/s.
See the link that the other post pointed out.
Zane
Russ in SoCal
12-18-2004 22:44:10
Rod,
Is the Freeman a similar unit to the Ford 701 and 702 loaders? I"m thinking it is but not sure. The man you really want to talk to is Zane Sherman. Check his website for some neat stuff he has come up with then email him and ask away. He"s the most knowledgable guy on this board and real good about sharing what he knows. Do you want live hydraulics or an independent system for the loader, or both? I got a loader with a front pump driven with a stinger shaft off the front pulley on the crank. Leaves the tractor hydraulics free for whatever. The common problem is the "slick" part. The basic loaders were just that: basic. Then one had to buy a mounting kit for the particular model tractor and an adapter kit for independent hydraulics. Nowdays, the loaders are all over the place, but finding a kit for YOUR tractor can be a problem. Most guys get an idea of what it looked like and then build their own brackets. See if Zane can give you some good direction.
Russ
12-19-2004 05:15:31
 Re: Cross-posting from Fergie site: adding a pump in reply to Russ in SoCal, 12-18-2004 22:44:10
I don't think finding another old loader would be a problem at all. I'm very interested, however, in how you hooked up your hydraulic pump, which pump it is, and where it is located. If you have any pictures I would appreciate them.
I'm new at this but I have the ear of a retired welder with lots of knowledge. If I can pick up components on eBay or the used market I hope to put a package together for him to install.
9n141
12-19-2004 19:08:37
 Re: Cross-posting from Fergie site: adding a pump in reply to Rod in Smiths Falls, ON, , 12-19-2004 05:15:31
Rod maybe we can get you an answer closer to home. I am in Athens, send me your phone # by e-mail. BURT
12-19-2004 19:27:26
 Re: Cross-posting from Fergie site: adding a pump in reply to 9n141, 12-19-2004 19:08:37
Burt:
613-283-8376 evenings
Rod Croskery
