Order Ford 8N Parts Online
Brake cross shaft bushing removal/'47 8N
rasputen
12-19-2004 11:09:37
'47 8N (no ideas from archives)
Before I destroy these, anyone got suggestions for removal of the brake cross shaft bushings from the trumpets?Since these are blind holes I an leaning toward splitting with dremel & using old screwdriver to crush inward.
No fire wrench, and would be afraid of cutting welch plug anyway.
Bushings on order from Don B.
That & bent left cross shaft are the only things holding me up from finnishing brake/bearing/hubs replacement job.Going for DRY brakes for first time in years!!!!
Gonna see if local machine shop will press bend the shaft back straight monday.
nevermind-done
12-19-2004 11:21:53
 Re: Brake cross shaft bushing removal/'47 8N in reply to rasputen, 12-19-2004 11:09:37
Went to take a better look & got them both out with a cheap screwdriver.
I was just wary since I am prone to destruction from sutpidity, (see sig).
oophs- no sig this board
12-19-2004 11:24:04
 Re: Brake cross shaft bushing removal/'47 8N in reply to nevermind-done, 12-19-2004 11:21:53
The sig line I refered to is:
I learned to fix a lot of things by breaking them first!
