pedal switch or solenoid?
RMK
12-20-2004 20:42:09
Fresh charged battery. Starter turned over a few times. Then nothing. No clicks. Nothing. Is it most likely the solenoid? The starter foot pedal switch? Or the starter? How do I diagnose? Thanks. RMK
Dell (WA)
12-21-2004 00:35:53
 Re: pedal switch or solenoid? in reply to RMK, 12-20-2004 20:42:09
RMK..... ....your 3-terminal starter solenoid is fairly bullettproof. but..... ..the BIG thumb button by the trannys shifter can be making poor connection when you push on it. Simple test, ground your little middle solenoid terminal (tranny in neutral, of course) with a jumper wire. Iff'n it cranks, yer solenoid is good. (maybe, could be BADD BATTERY CABLES)
Remember the 6 volt MANTRA: "keeper kleen, bright, and tight" and don't be fer usin' enny of them thar wimppy ferrin made battery cables. Gittcha some 'arrychested 'mercum made one-aught (1/0) thick as yer thumb battery cables..... ....Dell
old
12-20-2004 21:28:47
6 or 12 volt? if its six hows the battery cables? are they the auto type if its 6 volt they are not right/not big enough.
