power converter
Richard Jimenez
12-26-2004 07:22:45
I am the proud owner of a '46 2n.I want to keep it 6v but would like to put 12v lights on it. I have not been able to find a step up. Can anyone please tell me where I may be able to find one???
rasputen
12-26-2004 19:55:20
 Re: power converter in reply to Richard Jimenez, 12-26-2004 07:22:45
Not to say you SHOULD do this but it IS possible.
It's called a voltage doubler, don't think it would be quite good for a tractor, but SOME of us like going against the grain(like me).
Leroy
12-26-2004 17:02:19
If you have the old bulb and reflector type lights then just go to new sealed beam 6 volt lights, will be a lot brighter
souNdguy
12-26-2004 15:53:45
Like Dell said.. a power invertor is going to be a hard row to hoe for te inexperienced.
You are probably used to looking at 2 55w 12v bulbs.. ( 110w ) your 35w 6v jobs look dim.. 70w total. Add a 3rd 35 watt light.. giving you 105w. Yor genny will be having a hard enough time as it is anyway.. might as well make it work harder eh?.
Soundguy
Dell (WA)
12-26-2004 08:10:41
Richard..... ..electronics/electrics don't work that way. Step-down volts by power resistors convert excess volts to heat and throw it away.
There is a specialized technique that does "step-up" volts, its called an INVERTER POWER SUPPLY. They are NOT COMMON and are expensive.
You want brighter lights? Just replace your old with new 6v lights (they do gitt dim with age) ...AND... make certain that your wiring is good and heavy duty (12ga). Make certain your GROUND is a seperate wire, DO NOT RELY on rusty sheetmetal contacts/joints for ground. Remember the 6-volt MANTRA: "keep'em clean, bright, and tight"..... ...Dell
