hood removal
David Gremillio
12-29-2004 13:36:10
Is there a trick to the removal of the ford 8n hood? It seems unnecessarily complex. Any ideas would be welcome.
dg
rasputen
12-29-2004 15:18:35
 hood removaldog leash 2x4 method in reply to David Gremillion, 12-29-2004 13:36:10
third party image
Try this if you have somewhere to hang it from.
Easy 1 man method.
trg WY
12-29-2004 18:15:52
 Re: hood removaldog leash 2x4 method in reply to rasputen, 12-29-2004 15:18:35
Was wondering how you like the exhaust pipe position? trg
rasputen...
12-29-2004 19:00:50
 Re: hood removaldog leash 2x4 method in reply to trg WY, 12-29-2004 18:15:52
HUH??? Am I missing a joke here...or are you asking him??
DUCK
12-30-2004 03:56:15
 Re: hood removaldog leash 2x4 method in reply to rasputen..., 12-29-2004 19:00:50
That exhaust pipe seems to be blowing out toward the front of the tractor. I guess that is alright however I prefer having it blowing out under the step plate and toward the back.
valhallareject
12-29-2004 14:01:29
 Re: hood removal in reply to David Gremillion, 12-29-2004 13:36:10
Either park under a good shade tree.....have stout rafters in your barn or garage..... or get your wife or kids to help! Drain the gas.....disconnect the lights (if you have any) BEFORE you are trying to walk away with the hood....disconnect the air cleaner.....and lets see...what else.....oh yeah....be sober! Its not that its all that heavy.....just sorta oddly balanced....and whoooooweeee....is there a lot of expensive things that can get messed up....like a radiator!!!
OH Boy
12-29-2004 13:58:33
Whats complex about it? Unbolt it and lift it off.
Dell (WA)
12-29-2004 14:57:04
 Re: hood removal in reply to OH Boy, 12-29-2004 13:58:33
yep, nuttin to it. 4-dash bolts and 2-dogleg bolts and watch the grill fall out onto the ground. (oops) My 9yo son and I removed our 8N's hood in 15 minutes and walked it foward and set it down on some convient sawhorses. (tip: drain the gastank first)..... ..Dell
