I have decided I will dissassemble and reassemble my NAA Project Rustbucket's engine myself. I will obviously need an engine stand to accommodate this project. I am renting an engine lift today for the weekend so I can raise it to the engine stand. My questions are this:What size (maximum lbs.) engine stand will I need for a fully loaded NAA engine? Has anyone had any luck with the Harbor Freight engine stands lining up with the bolt holes on the end of the engine? I do not have the equipment to fabricate modification plates. If no experience with the HF models, any reasonable priced engine stand would do. I would really like to do what Ramrod has done and make some brackets to mount the engine to the stand from the distributor side so you can work on the rear of the engine while it is on the stand, but since I can't fabricate these brackets, what do I need to remove from the rear of the engine before placing it on the stand? I have already removed the rear cam shaft plate and removed the hydraulic pump gear - as that was obvious. One more - since I am removing all the parts, and just using the machine shop to turn the crank, dip the block, and press out/in new sleeves, can I remove the pistons from the back side once I remove the crank? I don't have a ridge reemer and I have just enough edge to catch my finger nail, so it may give me trouble pushing it out the top. Don't want to buy/rent a ridge reemer unless I have to. Thanks for all the advice so far. Dan
