spinning on ice/snow
8ngreenhorn
12-31-2004 05:24:12
Our N proved priceless by pulling our cars through our 1/4 long drive. I'll have a blade by next year's 14" snowfall.
My right wheel seemed to provide the only power. If I applied a little brake, would the left wheel have helped? I've got a lot to learn, but I do know that that N out there will never leave this family.
ericlb
12-31-2004 07:25:57
 Re: spinning on ice/snow in reply to 8ngreenhorn, 12-31-2004 05:24:12
most definatly use the brake, but sparingly, you'll have to experiment to see what works best for you, for me i have to feather both brakes depending on what im doing, my driveway is steep as well as the road and ive found the best way up it in the snow is to put 1 side of the tractor in the small ditch on the side,[ its only about 3 inches deep] then lightly applply the other brake, it will climb right up the drive or road, dont try this if the ditch is very deep, i have no chains and no fluid in the tires, it does have its limits, but i can usually spend time and get the job done, remember, " N TIME IS FUN TIME" ..you do have a set of those insulated coveralls right?
Bruce (VA)
12-31-2004 06:22:15
Learning the trick to minimize wheel slip by playing with the brakes is very important. And, chains are wonderful. Wheel weights and fluid in the rear tires, along with the chains, will give you the best possible solution. However, if you only have one N and use it for other things than snow removal, my advice is to skip the weights & fluid. Once you drive a tractor with weights & fluid in the tires across a less than totally dry pasture, you will see what I mean!
Ron/PA
12-31-2004 05:37:04
Yepper, your brakes are your slip controll. Chains would also help alot. Glad you like it. Ron
