Source for obtaining a 1/2 ohms, 10 watt creamic r
Rolf
12-31-2004 08:23:03
In his posting on January 21, 2002, Dell recommended using the above mentioned resistor when using a 12 volt coil on a 8N Ford front mount distributor. Can anyone furnish the name of a supplier and/or a part number for this resistor. Any information will be appreciated!
Dell (WA)
12-31-2004 12:26:43
 Re: Source for obtaining a 1/2 ohms, 10 watt cream in reply to Rolf, 12-31-2004 08:23:03
Rolf..... ...I always post the RadioShack p/n 271-131, 2-pack of 1-ohm 10-watt resisters when I recommend my secret current limiter resistor trick for the 12v squarecan frontmount ignition coil. You don't haffta use RadioShack for a resistor source, but you won't gitt that value resistor at an tractor/autoparts store, just industrial electronic stores..... ..... .Dell, a 12 volt advocate for the right reasons
Jay 2NSC
12-31-2004 08:57:59
Rolf, some have said to solder the end"s after twisting them together. HTH, Jay 2NSC
TIMW(PA)
12-31-2004 08:42:35
third party image
Radio shack
Bob
12-31-2004 08:28:45
The easiest to find solution is to use 2 - 1 Ohm 10 Watt resistors in PARALLEL.
Link:
