If you have a woman in the house, send her shopping, and "borrow" the oven to heat the ring gear. It's a LOT more even heat than with a torch, and you have an idea how hot it's getting. Preheat the oven to 450, take note of which way you want the ring gear to be oriented, an put it in the oven for 20 minutes, or so. Have the flywheel sitting an something secure next to the oven, clean and ready for the ring gear. (I often put the flywheel in the freezer overnight to shrink it a tad, and remove it and set it next to the oven just before the ring gear is "done".) Grab the HOT ring gear with GOOD oven mitts, and drop it in place on the flywheel. Have a hammer and a brass drift punch at hand, to be sure it's seated all the way. (You only have a couple of seconds to be sure it's in place before it shrinks down on the flywheel.) (You need to disassemble the clutch to get at the flywheel bolts. Match mark the pressure plate to the flywheel. While you're at it, mark the oreintation of the flywheel to the crankshaft, to make installation easy. Note the orientation of the lined clutch disc (which is front or back) and put it back the right way! You will need a clutch alignment tool when reinstalling the clutch. Some use the tranny input shaft, and install a new front transmission seal before putting the shaft back, to eliminate the chance of a leak there.)
