Order Ford 8N Parts Online
Another 8n drawbar question
R Wyler
01-04-2005 09:24:32
I am not sure the model of my 8n yet and I didnt get the serial it has the old style gear shift levever with the solid cast end in it the small ball not the big screwed on one. What I want to know is do all 8ns have the monting place on the bottom of the rearend for that drawbar set up the one that has the 2 brackets one for around the pto and the other underneath. Thanks
lonestarjeff
01-04-2005 19:53:42
 Re: Another 8n drawbar question in reply to R Wyler, 01-04-2005 09:24:32
My early(July)"47 8N has the clevis mounting holes underneath. Since they changed over to 8N production in June of "47 it makes me wonder if the new castings maybe overlapped a little into the late 2N"s. I wonder if anybody knows for sure?
By the way, I"ve seen Dearborn literature somewhere showing a picture of a large "horseshoe" shaped drawbar attached to the lower links on an N. It had multiple holes like the straight fixed drawbar. That was likely the type used on the 9N/2N.
Jeff
Larry 8N75381
01-05-2005 09:52:44
 Re: Another 8n drawbar question in reply to lonestarjeff, 01-04-2005 19:53:42
Jeff, how early is your 8N? I have 8N1045 and it has the mounting holes in the diff. housing for the drawbar clevis. It would have been easy to modify the mold patterns to provide the bosses needed to mount the clevis, so I suspect that was a feature "new" to the 8N's and thus included on all of them.
Regards,
Larry
lonestarjeff
01-05-2005 14:33:29
 Re: Another 8n drawbar question in reply to Larry 8N75381, 01-05-2005 09:52:44
Larry:
I have 8N 4778. I think you"re right, all the 8N"s had the new castings. I can"t help but think w/ all the changes made in the turn-over from 2N to 8N some of the tractors were "hybrids". Some old 2N parts & some new 8N parts. Can"t imagine Henry II stopping production to make the change, but who knows?
Jeff
R Wyler
01-04-2005 20:09:57
Thanks for the info Jeff. That would be interesting to find out. I would like to see some pics of old dearbord literature.
R Wyler
01-04-2005 18:44:15
 Re: Another 8n drawbar question in reply to CraigNAA, 01-04-2005 18:41:23
Thanks Craig I was over at that site today it has a wealth of info and parts sources. I will go look at them.
Brian S, NE
01-04-2005 10:22:53
My '48 has the 4 holes under the diffy. I bought mine right here. Did have a problem with the holes on the new clevis not lining up. The folks here sent another one right out.
It is a lot easier to deal with than the original.
Brian S, NE
'48 8N 60896
R Wyler
01-04-2005 10:52:07
 Re: Another 8n drawbar question in reply to Brian S, NE, 01-04-2005 10:22:53
Thanks Brian. I was wondering of those would maybe not line up just right but it is no big deal easily corrected. I am going to for sure get one of those hitches for mine. I will get the serial number as soon as I get it to the farm. The steering has ALOT of slack and it is in the steering gear I noticed.
crazy8
01-04-2005 09:36:18
the 8ns originally have a clevis under the pto, not the drawbar hanger that mounts directly around the pto shaft.Then there was a rollerdrawbar that connects to the clevis and to a crossbar on the liftarms, with staybars from the toplink on the tractor.dearborn made these drawbars. If your not doing a restoration the later style or aftermarket drawbars are a lot more conveinant to use, they retail for around a $100.00
R Wyler
01-04-2005 09:39:25
 Re: Another 8n drawbar question in reply to crazy8, 01-04-2005 09:36:18
Thanks for the info. I do like things original and for the most part this tractor will remain original. I really want that new style one for $100 I was wondering if the first 8ns also had the mounting holes for this down underneath. I discovered the 9n and 2n do not and it made me wonder if the first 8ns are that way also.
Dell (WA)
01-04-2005 09:46:09
 Re: Another 8n drawbar question in reply to R Wyler, 01-04-2005 09:39:25
Wyler..... ....as far as I know, ALL 8N diffys have the 4-bolt cast-in mounting boss underneath the diffy for mounting the swinging draw. You are correct the 2N/9N does NOT have the mounting boss..... ...Dell
R Wyler
01-04-2005 10:17:36
 Re: Another 8n drawbar question in reply to Dell (WA), 01-04-2005 09:46:09
Thanks for the info Dell. I am sure it does then. If it doesn't happen to have it and I am sure it does I can always set it up like the 9n and 2n. I wonder why they didn't make the 9n and 2n to take that type of drawbar as well it looks like neat setup and about as safe as a drawbar can get on a tractor of that design. I know the lower the better and also the center of pull is farther forward than the very rearward mounted types.
rasputen
01-04-2005 17:05:50
 Re: Another 8n drawbar question in reply to R Wyler, 01-04-2005 10:17:36
My '47 8N (sn 34055) built in the late fall/early winter of 1947 has what looks to be stock clevis from the factory. I have never had the swinging drawbar as I would like to get a real one and never blew the $100 on the whole aftermarket kit just for the bar & pin.
R Wyler
01-04-2005 17:08:20
 Re: Another 8n drawbar question in reply to rasputen, 01-04-2005 17:05:50
Thanks for the info. Mine will surely have that also. And I am going to get that drawbar they look very nice.
